Bizhub C368 install troble
  • Scorpion1980
    • Jan 2022
    • 13
    Good morning
    I have a bit of trouble and I hope you can help me.
    I am currently trying to install a C368 over TCP/IP on a Windows 10 pro clean install. It responds to pinging, when I try to add TCP/IP printer from control panel it tries to comunicate with Windows and then nothing. From another laptop (also Windows 10 pro) it can be installed and works perfectly.
    On the same PC I have a C220 installed, which works. For C220 I can access the web interface, for C368 I get a connection reset message. What am I doing wrong?
  • aberock
    • May 2022
    • 124
    Re: Bizhub C368 install troble
    Originally posted by Scorpion1980
    Good morning
    face this issue before , on same network but some pc cant detect the copier .
    always did all clear and all problem solved , all pc can be access . not sure which setting caused
    • Scorpion1980
      • Jan 2022
      • 13
      So you recomand a reset from service mode of the C368?
      • aberock
        • May 2022
        • 124
        yes did a all clear .
        issue what i faced like :
        • able to ping copier
        • able to access via browser
        but unable to install driver , showed offline
        • Scorpion1980
          • Jan 2022
          • 13
          Damn.
          The C368 responds tot pinging, but I am unable to access the web interface.
          The other one, c220, responds tot pinging and I can access the web interface
          • Scorpion1980
            • Jan 2022
            • 13
            Nope, nothing even after the reset from service mode. Anyone with a better idea? If not, I will try to reinstall Windows, maybe I will try a downgrade to Windows 8
            • aberock
              • May 2022
              • 124
              Damn.
              C368 firmware version ?
              • Scorpion1980
                • Jan 2022
                • 13
                Got the sucker!
                Took down *ALL* Windows 10 updates and did a clean install. Damn, such a beginner solution
                Thanknyou for ALL the answers
