bizhub C3320i scanner section
  • jwai
    • May 2018
    • 517
    Hello,
    One customer reported their C3320i seldom have all black copy and all black scan image, printing is OK.
    I tested it many times, and one time I saw the exposure lamp didn't turn on while ADF scanned document. I tried to reconnect flat cable of scanner, checked service call history but not found any code.
    Anyone have this experience on this issue? which component would cause this?
  • Albonline
    • Sep 2008
    • 1154
    Re: bizhub C3320i scanner section
    Originally posted by jwai
    Hello,
    yes i have dealt with this a few times on units with high scan counts. the flat cable conductor runs crack internally. remove the brown tape and hold it to the light the cracking will be apparent.
    • jwai
      • May 2018
      • 517
      thank you, so replace flat cable is the right way? and that cable is same as one on C3350i?
      • elmaligno
        Expert technician KM
        • Oct 2009
        • 302
        No, the C3320i carries part AAJPN11500 which is exclusive.
        I advise you to change also the connector of that cable: A7AHM90000, as it will break when you remove it (and I don't have a crystal ball).
        Field technician since 1994
