konica minolta c2557 code bizhub 658e
    • 22936
    #46
    Re: konica minolta c2557 code bizhub 658e
    Congratulations on your success! =^..^=
    • mitchl
      • Apr 2007
      • 501
      #47
      Originally posted by brent
      ok wanted to update the problem. so the toner drive assy came in today.. the machine was mostly tore down so I had to dig a little deeper and get to it. replaced te unit. also I see the new gear on that unit has smaller type different fins. so to speak. that was not fun but anyways put it in and all back together. still almost pure white copies but no code. like last time.. so then I unplugged it and tore the front of the machine off and I replaced the front cover/ toner hopper. (I already did this and used a working unit) but it didn't work suposedly. put it all back together. and did a manual toner add. it spun today for the first time. toner level was 0.0 then to 1.9 then a couple toner adds later. it is at a 6.25 now 6.80 black copies are back. so I am not sure if the toner add assy or the toner hopper assy was bad it is all new and I did not have to replace the dv unit for the 4th time even though I have some in stock now. so I think we got it. the only other thing I cant clear is the d3 split line back side. which I will reserach that later.
      so thank you everyone!!! I will run this at the office for a couple weeks. to verify it doent take a shat.
      just not sure why the toner hopper off a working machine didn't work on this one. I will chuck it and put a new one on that other machine
      something in the hopper it was trying to add toner. but just was noisey it was probably broken 0r some thing stuck inside and I just
      didn't know it. thanks all I love this board
      brent
      Do yourself a large Brent and take the sub hopper apart so you understand whats in it and see if the shaft that runs front to back isnt off its back holder. I still would wager that that was the problem all along. If its off the toner builds up satisfying the level sensor so the machine has no reason to spin the bottle as it thinks its full. Glad to hear the machine is back in order!
      • brent
        • Nov 2008
        • 1208
        #48
        I would but I took a hammer to it.. just kidding I have it here I will take it apart there must be something in there and im not sure why the take off wouldnt' work.. I probably didn't even need the toner drive motor anyways lol live and learn I guess. thats what I get for overthinking it.. the toner hopper determines when the bottle spins according to some of you guys so I was chasing the wrong dog perhaps.. but for now its fixed thanks
        appreciate you all
