Bizhub c368 c2552
  • mrfuser
    • 1626
    Bizhub c368 c2552
    Client has a fairly new c368, meter around 50k. Keeps popping up a c2552 over toned cyan developer. I can go in and do some screen shots and get it back down to normal level as and then later it comes back. Any ideas why this is happening?
    • 14972
    Re: Bizhub c368 c2552
    If any of the drums are close to or over yield it's probably a good idea to replace them. Otherwise replace the dev unit
    • KMFLT3CH
      • May 2017
      • 242
      Aftermarket/knockoff toners can cause abnormally high TCR %, been seeing this a lot lately with 8 series not using OEM toner. You can run dozens of halftones at 255 to bring the level back down but it will creep back up slowly.
