konica c7000 bypass tray mb504 does not rise
  • zubinn
    • Sep 2017
    • 49
    my pf601 paper tray died. so i removed it and want to use the bypass tray to run some jobs only to find it does not rise.
    It does show up on the machine as bypass tray dipsw 36 is on
    problem is the tray does not lift. If i force it up when the machine is trying to draw paper in it does print.
    i have tried replacing the lift motor A0P0M10000 from another machine unfortunately it doesnt work.
    Any ideas ? did i miss anything ?
  • Synthohol
    Certified Konica Expert
    • 5814
    Re: konica c7000 bypass tray mb504 does not rise
    recheck all 5? connectors, sounds like the lift motor is not plugged in.
    or ive seen the tray limit actuator stuck so it thinks its up all the time.
    • zubinn
      • Sep 2017
      • 49
      the lift motor is connected 2 pin connector. I tried a new motor also….
      but what you mentioned about the tray limit actuator may be something to look into
      would you be able to give more details on the tray limit actuator, where it is located and how to check it?
      • Synthohol
        • 5814
        • zubinn
          • Sep 2017
          • 49
          is there a dipsw setting to test ps25 and m35 ?
          if anybody would like to do a video call with me I be willing to pay hourly to help troubleshoot
          • tulintron
            • Jul 2014
            • 668
            I suspect you have a damaged Conveyance Drive Board. I've been through this a few times. There is a green colored ICP right below the engine. It is in the top right corner of the Board. Check if it is burnt.
            • Synthohol
              • 5814
              should be ICP11
              • zubinn
                • Sep 2017
                • 49
                should be ICP11
                this board ? I see 2 flashing led
                see bigger image >>> Shared album - Zubinn Tan - Google Photos
                • zubinn
                  • Sep 2017
                  • 49
                  Does this bypass tray mechanism look okay ?
                  see bigger picture >>> Shared album - Zubinn Tan - Google Photos
                  maybe some bits need to be replaced.
                  • Synthohol
                    • 5814
                    on that assy, the sensor that the feed assy blocks as the paper rises it looks like the metal frame is bent and the metal actuator never gets blocked and unblocked. bend the metal so the arm goes deeper in the sensor to block the eye.
                    The frame the sensor is mounted looks bent and the sensor is not being blocked by the actuator arm.
                    • zubinn
                      • Sep 2017
                      • 49
                      picture from a diffrent angle ... sensor blocked / unblocked
                      if "bending" is required bend in which direction ?
                      blocked >>> Shared album - Zubinn Tan - Google Photos
                      unblocked >>> Shared album - Zubinn Tan - Google Photos
                      • zubinn
                        • Sep 2017
                        • 49
                        picture from another angle ... bend which metal up or down ?
                        sensor blocked >>> Shared album - Zubinn Tan - Google Photos
                        sensor unblocked >>> Shared album - Zubinn Tan - Google Photos
                        • Synthohol
                          • 5814
                          ok, so when you go to use the bypass the solenoid engages, the feed assy is supposed to drop onto the paper and the tray should rise then start feeding once that sensor is blocked and shows "paper set"
                          so either the lift motor is not energized or the solenoid that is supposed to release the take-up assy isnt releasing.
                          • zubinn
                            • Sep 2017
                            • 49
                            how can i test these ? is there a dipsw setting that i can see the motor / solenoid status ?
                            • Synthohol
                              • 5814
                              23 0 M38 Paper lift motor /1
                              1 M39 Paper lift motor /2
                              2 M40 Paper lift motor /3
                              3 M35 Paper lift motor /BP (down)
                              4 M35 Paper lift motor /BP (up)
