FS-532 on a C2070
  • methogod
    • Dec 2008
    • 921
    FS-532 on a C2070
    Is there a dipsw that limits or takes the limit off capacity of the stacker.
    Seems like it is "Full" at about 2000 sheets of 11x17, should be able to do more.
    its not at its lower limit, with 2000 sheets, and the weight seems fine.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4702
    Re: FS-532 on a C2070
    Here are the specs for FS532: Paper Capacity Available for Use
    Not sure if it has something to do with the limit but the weight is equal to 4000 sheets of 8.5 x 11. That's almost a case of paper which as you know is very heavy at 50 lbs.
