Minolta Di470
  • digicor
    • Jul 2008
    • 1158
    Minolta Di470
    Im having a real problem with a di 470.It will make one copy, try to do two it stops shows a jam at the sep corona, the paper is 1/3rd the way past the sep corona.nothing caught,nothingjammed.I changed the sep corona, the charge corona, i even changed out the e promm.I will not print multiples from the internal paper passage f12 command, it does the same thing.heres the odd part, it WILL print multiple's if you select the paper in landscape and take it off auto for everything,(man peper select)and disconnect the finisher????anybody got any ideas? im out of hair.....LOL
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Sounds like a timing issue. Is the registration off on the 2nd (jammed) page? Check the timing and transport clutch.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      I agree. Out of time at the reg roller would make it stop at the transfer.
      • digicor
        • Jul 2008
        • 1158
        thanks guys
        ill let you know what give's
