bizhub C227 Marketplace
  • asheer.singh
    • Jul 2023
    • 20
    Hi,
    I have a bizhub C227 which is running the latest firmware. Is it possible to enable the bizhub Marketplace on this device?
  • kingarthur
    • 1390
    Re: bizhub C227 Marketplace
    Originally posted by asheer.singh
    Hi,
    I don't see why not, I'm using Marketplace on a C458 in our office without any problems
    • asheer.singh
      • Jul 2023
      • 20
      Thanks. How do you enable. It?
      • kingarthur
        • 1390
        as far as i can remember, once you've configured the device, you use the "marketplace installer" which is downloaded onto your PC from the marketplace web page, the latest version I can see is 1.14.10, once you've done that, then you can start adding apps - all the instructions are on the market place web page under "support", the installer is there too
        • asheer.singh
          • Jul 2023
          • 20
          Thanks. I managed to get it installed and working
          • mitchl
            • Apr 2007
            • 501
            This may be a first, most only want to disable the little nightmare and its obnoxious screensaver.
            • asheer.singh
              • Jul 2023
              • 20
              I will probably uninstall it. I wanted to have a look at what Apps were available and try out the OneDrive Connector App
