Bizhub C250i hopper problem!
  • otphas
    • Aug 2019
    • 119
    Hello Guys ,
    we have a C250i with a strange problem . M and K TCR values are to less around 1% , we add manual toner and TCR value going to normal, but we noticed that when we try to add manually toner to hopper section toner bottles not turning and hopper not filling. We think this is a reason why Dev unit is empty and TCR value is out of range. Any suggestions ?
  • mitchl
    • Apr 2007
    • 501
    Re: Bizhub C250i hopper problem!
    Have fun and bring a vacuum!i series toner add.pdf
    • mitchl
      • Apr 2007
      • 501
      I just noticed your in Valletta, I'm fortunate enough to have been to Malta twice, pretty amazing place with incredible history. Mdina is one of the coolest places on earth!
      • Lync
        • Feb 2016
        • 47
        Originally posted by otphas
        Hello Guys ,
        Vacuum out some of the toner in each hopper until you can see the toner level sensing arm at the back, it comes off the hinge and doesn't detect the toner level correctly. This can be clipped back on. Also look at the sensors under the hoppers just above the developers and make suer they are clean. Because of the clip that holds the toners in, there is a hole that toner drops down and dirties the sensors.
        See attached PDF:
        Low TCR broken toner drive premature replace toner messages.pdf
        • otphas
          • Aug 2019
          • 119
          The machine is fixed , thanks for the manuals!
          • tsbservice
            Field tech
            • 8028
            How?
            • otphas
              • Aug 2019
              • 119
              We opened the hopper section and noticed that mechanism for toner level was somehow not in the right place and sensor for toner level was blocked and gave wrong signal that hopper section is full, but was totally empty!
