C-360i Control Panel issues...
  • Oystercopy
    • Oct 2009
    • 623
    Hey guys.
    So I delivered this machine used a few months ago. Only has 41K on it. Went out there today for a problem where the screen will not HOME, when the home button is pressed. Seems to allow every other icon to function on the panel, but when the customer is at (say) the Scan screen, and they want to return home, they can't do it and have to turn the machine back off and on and even unplug it from the wall sometimes to get it back.
    My understanding is that this can simply be a display calibration issue, but wondered if anyone had anything else to add.
    Thanks!
    OC
  • Digital
    • Feb 2021
    • 17
    Re: C-360i Control Panel issues...
    Never had this problem on i-series.
    Try with firmware update and a display calibration
    • mojorolla
      The Wolf
      • 2596
      Have you disabled the Marketplace app?
      I have seen several issues with the op panels on iSeries when using the Marketplace app.
      • rrrohan
        • Sep 2011
        • 1976
        Is it set to go back to home screen after idle for 60 seconds and not doing that or do you mean when you press the home icon it doesnt go home
        • Oystercopy
          • Oct 2009
          • 623
          Thanks guys.. No, I think the panel is set to go home after 60 seconds but its not doing that either. Yes, the marketplace is disabled (I do this on all the machines) and NO, it will not go home, even if the home button is pressed. Strange how it will make every other icon available other than the home, but I'm going to try calibrating (the TP setting seems to be more about sensitivity than actual calibration).
          OC
          • occus
            • 332
            OC
            It's always a pleasure to read something like that:
            GC2-Q8
            This firmware has an issue where the reset key does not respond after waking up from power save mode. The issue of the reset key not responding will not occur if you set software SW No. 227 Hex02.
            ...I can remember a piece of information about the screen not switching to the home screen, but unfortunately I can't find anything more about it.
            But look at this:
            Release version and download file name
            The newly released program version and download file names are as follows.
            [Release version]
            Model(ineo)
            Data
            +450i/+360i/+300i/+250i
            +550i (without memory board)
            FW_AA2J0Y0-F000-GXX-33.exe
            +650i/+550i
            FW_AA7N0Y0-F000-GXX-20.exe
            +750i
            FW_ACKN0Y0-F000-GXX-20.exe
            450i/360i/300i
            650i (without memory board)/550i (without memory board)
            FW_AC770Y0-F000-GXX-34.exe
            650i/550i
            FW_AC740Y0-F000-GXX-34.exe
            750i
            FW_ACV70Y0-F000-GXX-20.exe
            [Download File Name]
            Eagle Touch Panel issue_Develop.xlsx
            PRI_DLKM_BT2312431EN_**.doc
            2. Fixed issue
            To fix the issue that the touch panel does not work when it is touched.
            The Jig firmware can be applied to the machine with Panel CPU ver. A2J0Y0-8900-G30-08
            and updates it to A2J0Y0-8900-G30-09.
            Please refer to [Eagle Touch Panel issue_Develop.xlsx] for Serial numbers of the affected machines.
            3. How to install
            Same as the way for updating MFP firmware.
            • rrrohan
              • Sep 2011
              • 1976
              i just had to replace a touch screen that kept freezing on a c300i
              its handy to have a spare touch screen as you can simply plug it in at the IO panel and leave it on a table or something next to copier for customer to trial for a few hours.
              the 2nd cable is just for the haptic feedback so for testing u can live without it
              • femaster
                • May 2011
                • 1482
                There was a special Panel CPU firmware issued in the US market to prevent the issue of non-responsive touch screens. I would assume it is available in other markets as well. Below is a chart that outlines the models, serial numbers, and firmware version for each.
                Overview
                An issue has been identified in specific serial numbers where the Operation Panel Touch Screen becomes unresponsive to
                input.
                Solution
                For MFPs exhibiting this issue and falling within the specified Serial Numbers below:
                • Update the Panel CPU firmware version from A2J0Y0-8900-G30-08 to A2J0Y0-8900-G30-09 using Special Firmware GXX-xx available via the One-Stop Product Support webpage.
                • C550i: Take note of the machine’s Serial Number (to identify “with Memory Board” and “without Memory Board” machines; reference Technical Bulletin 12791) before downloading and installing the Special GXX-xx Firmware.
                Serial Number / Special Firmware
                Model Main Body
                Serial Number
                Panel Unit
                Serial Number
                Memory
                Board
                Special Firmware
                C250i From AA2M011014905
                To AA2M011019189
                From AA2JM700MJ406708
                To AA2JM702MA800953
                - FW_AA2J0Y0-F000-GXX-33.exe
                C250i From AA2M013008875
                To AA2M013009029
                From AA2JM700MJ609665
                To AA2JM700MJ210607
                C300i From AA2K011016362
                To AA2K011999999
                From AA2JM700MJ607434
                To AA2JM702MA206081
                C300i From AA2K012001699
                To AA2K012002313
                From AA2JM700ML436127
                To AA2JM702MB401306
                C360i From AA2J011019283
                To AA2J011024474
                From AA2JM700MJ210752
                To AA2JM702MA800933
                C360i From AA2J017000001
                To AA2J017999994
                From AA2JM702MA800934
                To AA2JM702MA402656
                C360i From AA2J012001698
                To AA2J012001915
                From AA2JM702MD600135
                To AA2JM702MD616907
                C450i From AA7R011023085
                To AA7R011028457
                From AA2JM700MJ208758
                To AA2JM702MB406245
                C450i From AA7R017000003
                To AA7R017500310
                From AA2JM702MD615765
                To AA2JM702MB806164
                C450i From AA7R012000628
                To AA7R012000680
                From AA2JM700MJ607714
                To AA2JM702MB405638
                C450i From AA7R018000001
                To AA7R018000015
                From AA2JM702MD217191
                To AA2JM702MD616701
                C550i From AA7P011702353
                To AA7P011705316
                From AA2JM700MJ607465
                To AA2JM702MB406561
                Not Installed FW_AA2J0Y0-F000-GXX-33.exe
                C550i From AA7P017700001
                To AA7P017700010
                From AA2JM702MD612938
                To AA2JM702MD615770
                C550i From AA7P018000001
                To AA7P018000015
                From AA2JM702MD813718
                To AA2JM702MD217361
                Installed FW_AA7N0Y0-F000-GXX-20.exe
                C650i From AA7N011007148
                To AA7N011008961
                From AA2JM700MJ609043
                To AA2JM702MA601376
                - FW_AA7N0Y0-F000-GXX-20.exe
                C650i From AA7N017000001
                To AA7N017000010
                From AA2JM702MD615764
                To AA2JM702MD810716
                C650i From AA7N012000249
                To AA7N012000318
                From AA2JM700ML435085
                To AA2JM702MD611930
                C750i From ACKN011004328
                To ACKN011005833
                From AA2JM700MJ805204
                To AA2JM702MB208310
                - FW_ACKN0Y0-F000-GXX-20.exe
                C750i From ACKN017000001
                To ACKN017000015
                From AA2JM702MD812230
                To AA2JM702MD213362
                300i Not Affected Not Affected - -
                360i Not Affected Not Affected - -
                450i Not Affected Not Affected - -
                550i Not Affected Not Affected - -
                650i Not Affected Not Affected - -
                750i From ACV7011001634
                To ACV7011002339
                From AA2JM700MJ805277
                To AA2JM702MD215706
                - FW_ACV70Y0-F000-GXX-20.exe
                750i From ACV7017000001
                To ACV7017000015
                From AA2JM702MD812234
                To AA2JM702MD213360
