TU 510 issues
  • emujo2
    • Mar 2017
    • 1579
    [Misc] TU 510 issues
    TU 510 will jam when anything smaller than 11x17 when trying to cut/trim. All sizes pass if not trimming. J-7739. We have tried various levels of F/W, both boards, cutter #1. 11X17 and larger work 100%. Any ideas?
  • emujo2
    • Mar 2017
    • 1579
    Re: TU 510 issues
    Issue turned out to be a not fully inserted plug into one of the conveyance section sensors. The conveyance section had to be removed to gain access to the panels that allow access to the sensors. What was confusing us was the sensors worked in test mode. Nothing worse than factory and/or tech induced problems.
    • allan
      RTFM!!
      • 5462
      Re: TU 510 issues
      I had to look up what a TU-510 does. You seem to have all the fun there. Like the way you just use CTN to answer yourself.
      Here is a YouTube clip of the TU-510 for those like me, unaware of what this was and the issues this can come up with.
      I have see a demo machine with this unit on before, the one time i got out from underneath my rock.
      Whatever
