Drum installation error K
  • Promise
    • Jan 2024
    • 19
    [Error Code] Drum installation error K
    Bizhub 360 show drum installation error K and I have tried removing it and reinstalling it and also change main board, drum sensor, swap unit with working one, change memory in printer board, check the wire that connect the drum sensor but still showing k please I need help
  • tsbservice
    Field tech
    • 8020
    Re: Drum installation error K
    360 or C360 or C360i
    • rrrohan
      • Sep 2011
      • 1977
      so u tried a knows working K drum and error continued?
      • Promise
        • Jan 2024
        • 19
        Bizhub C360
        • Promise
          • Jan 2024
          • 19
          Yes
          • ionutkok
            • Nov 2012
            • 24
            Perhaps the chip is not suitable. The chip on the black unit works only on black. The chip on the color unit works on any color unit. The chip on the color doesn't work if you put it on the black unit.
            • Promise
              • Jan 2024
              • 19
              Plz I need help Bizhub c360 is showing drum installation error K
