Di550 comes with C-0049
  • petrus
    • 155
    Di550 when doing copies the error code c-0049 comes out after 8 copies.-- this refer to paper source option vertical tansport cooling fan malfunction.this machine doesn't comes with the optional parts that mantioned.even I pulled all connector like feeder and fnisher.it still appear.I tried change all pwb from good machine but hopeless.
    I have check all cooling fan and motor and that all work propperly.
    If anybody have an idea please help me to solve this problem.
    I've spend 3 days on this machine to make its work.
  • 8050
    • 88
    This was from solutions, hope it helps.
    Subject:
    The Di450 displays Malfunction code C0049, paper source option vertical cooling fan motor malfunction.
    Description:
    Solution:
    The Vertical transport cooling fan motor rotation: the voltage across PJ4IA-1 on the power supply board and GND should be 24 VDC after the malfunction has been reset. If not, change the control board.
    The vertical transport cooling fan motor rotation: the voltage across PJ4IA-3 on the power supply board and GND should be 0 VDC after the malfunction has been reset. If it is 0 volts, change the control board otherwise change the motor.
    Please refer to the Field Service Manual (approx. 4 MB) for additional details.
    • buster68
      • Nov 2008
      • 181
      how many paper trays do you have on the Di550?
      • time2fly
        • Jul 2008
        • 134
        I believe that is a code for the main fan in the back buried right in the middle.
        • minoltaed
          • Aug 2025
          no thats a c0040 code for the suction fan in the back take off the side cover on transport side u will see the fan
          • petrus
            • 155
            This di550 comes with 3 paper tray.1 & 2 is universal tray and below the duplex is large capacity tray.
            I have visually check all the fan is rotating smoothly.
            unless the fan cannot be seen outside.
            • labish
              • 21
              C0049
              Vertical Transport
              Cooling Fan Motor
              malfunction
              • The Motor Lock signal (H) is detected continuously
              even after the lapse of a given period of
              time after the motor has been energized
              M132 find it and replace the fan. This machine comes with options PF 115 and 208 and the fans made wherever not to put names here are very bad quality. I work with this machines for some times and I've replaced a lot of fans fuser, suctions, optics, power supply but not this one. Hope I help in anyway.
              • petrus
                • 155
                I already found the fan.it a small fan.it located at rear of the machine.
                I change it and the machine now works,
                thank you all.
                • GRICH
                  • Feb 2024
                  • 4
                  Re: Di470 comes with C-0049
                  Di470 when doing copies the error code c-0049 comes out after 5copies.-- this refer to paper source option vertical tansport cooling fan malfunction.this machine doesn't comes with the optional parts that mantioned.even I pulled all connector like feeder and fnisher.it still appear.I tried change all pwb from good machine but hopeless.
                  • Synthohol
                    Certified Konica Expert
                    • 5847
                    Re: Di550 comes with C-0049
                    hope this helps.
                    • GRICH
                      • Feb 2024
                      • 4
                      thank you all.
                      vertical tansport cooling fan!
                      • GRICH
                        • Feb 2024
                        • 4
                        Please where exactly is the fan?
                        • GRICH
                          • Feb 2024
                          • 4
                          thank you all.
                          PLEASE WHERE IS THIS FAN CANNOT FIND IT
                          YOU CAN HELP ME with a photo or tell me where it is
                          • Matoku
                            • 173
                            Sorry Guys. this post rotten already. it more then 10 years ago. now We don't do service on Minolta anymore.
