konica minolta c287 copy quality
  • brent
    • Nov 2008
    • 1214
    the drums only have around 40k clicks on them. the problem is copy quality it will turn the gray area on a copy into purples. if that makes sense lol
    lastweek at this copier I was able to run gradation and was able to get the copies back to normal... but the customer called and said its doing it again.
    am I looking at new drums or ? I dont have any sample copies at present time to scan to show. also when I ran test mode halftone patterns the 4 colors came out perfect. just when you print or copy from glass is where I am having the issues.. any thoughts?
    thank guys
  • tsbservice
    Field tech
    • 8064
    Re: konica minolta c287 copy quality
    I would do manual toner add then stabilization plus reset then gradation. Look at tcr values also. Look for errors in service you know all of usual stuff.
    • aAandy
      • Apr 2012
      • 370
      thank guys
      silly question, but are they OEM drums? or aftermarket? if aftermarket and other suggestions don't work, go OEM
      • brent
        • Nov 2008
        • 1214
        • aAandy
          • Apr 2012
          • 370
          i never use aftermarket toner with these machines - too many print quality issues and you can end up chasing your tail looking for the cause of unusual print quality issues,,,,,
          • brent
            • Nov 2008
            • 1214
            some machines I get away with it.. the 364e color series seems pretty bulletproof with aftermarket supplies. but I have strickly gone to oem on the 658 558e series machines.. hopefully I can get there today to see whats up thanks!
            brent
            • allan
              RTFM!!
              • 5462
              thank guys
              Could be primary and or secondary transfer that leaves behind a thin layer on the drum or transfer belt that can cause the grey to be off. Had this issue on brand new machines. Grey like to go a bit blueish or it could just be color casting effect due to the light and surrounding colors in the room or other environmental conditions like temp and humidity Light grey is like 80,80,80 CMY in theory only. 80,80,75 can already look blueish.
              Light grey is the worst color to match.
              Whatever
              • tsbservice
                Field tech
                • 8064
                brent
                Hey brent, better don't experiment with compatible toners especially on color machines.
                The simple fact you have many mysterious threads here in forum tells a lot I think
                4e series have separate drum/dev while C287 has IUs for CMY and that should tell you something.
                If you want to play the game with compatibles you should be extremely cautious and have very deep knowledge in how they should work and what is acceptable and what not or initial money surplus from lower toners price can be easily converted to a big loss.
                I don't want to teach you how you should be doing your own business but give it as advise from tech to tech
                • brent
                  • Nov 2008
                  • 1214
                  tab I have always appreciated your advice on lots of threads here. I do very well on my business lol as far as toners I am going back all oem
                  internal prints are perfect. I do have a void line on magenta. I did the manual toner add in all colors then stabilazer. then I went to image process to gradation adjust and was able to turn that color back again today.. so I am just not sure if I have a few things going on now or what
                  brent
                  • 4Toon
                    • Mar 2023
                    • 112
                    brent
                    Replace belt would like to see a example but sounds like a issue from the belt that can happen on konica and kyocera i have seen this on.
                    Permanently banned from Konica SSD.
                    • brent
                      • Nov 2008
                      • 1214
                      I wish it was easier to post pics here.. I am going to give it a try lol
                      brent
                      • brent
                        • Nov 2008
                        • 1214
                        ok well I will admit what I did. lol there was a line on the copy and I seen no other way but to replace the magenta drum dv unit. well I replaced it and the line was still there I about shat lol it turns out the plastic cleaner for the slit glass below the drum was dirty my bad but they still got the drum
                        was there yesterday the colors just arent good when printing and its a bummer. maybe a 7 year old machine wont keep adjustments anymore I have thought about everything other then a belt and the other 3 drums. I do the gradation and other stuff it makes it better copy quality for about a week then we lost a color thoughts?
                        anyways thanks everyone for the help
                        brent
                        • Hap
                          • Jan 2017
                          • 34
                          thank guys
                          seen this beforew calibration fixes but comes back quikly replace primary transfer
