C-454e, "original left on glass"...
  • Oystercopy
    • Oct 2009
    • 623
    I read all the other posts on this issue on this board, but none of them seem to address the initialization of those sensors under the glass? Went looking for it in the SM as well, and could not find it there, only a way to enable/disable that function in the Admin mode...
    Thanks,
    OC
  • tsbservice
    Field tech
    • 8002
    Re: C-454e, "original left on glass"...
    Thanks,
    OC
    No way OC. I usually redo Adf setup make sure non image erase is OK, clean optics and CCD. That's working probably 99%.
      • 14648
      And make sure the magnet in the DF lines up with the reed switch under the front scanner cover
      • rrrohan
        • Sep 2011
        • 1977
        I had one a while back. If you reboot copier and never open scanner you could use adf ok. The moment you opened scanner from that point on it was convinced there was a A3 sheet detected. I replaced both size sensors and that fixed it
        Sent from my Pixel 4 XL using Tapatalk
        • Hansoon
          • Sep 2007
          • 3380
          Cleaning the underside of the platen glass helped me often with this problem.
          Even when looking “clean” there seems to be something which can be polished off.
          Hans
          • Oystercopy
            • Oct 2009
            • 623
            OK, so I went out there today, cleaned the optics and both sides of the glass, cleaned the actuator sensor in the rear, checked the front magnet, and then everything started working OK.
            Thanks for the all the help guys!
            OC
