bizhub 227 C-6756 error code
  • kranyan
    • Oct 2020
    • 10
    hello,
    i'm a computer tech trying to fix a bizhub 227 with the error code c- 6756 ,i dont know what to check and i dont have a service Manual.
    any suggestion please?
    Thank You.
  • allan
    RTFM!!
    • 5462
    Re: bizhub 227 C-6756 error code
    CCD error. Is the scanner lamp coming on at any time during the boot process?
    Whatever
    • kranyan
      • Oct 2020
      • 10
      Hello.Yes 'i checked the scanner lamp works when you wake up the machine.
      • femaster
        • May 2011
        • 1504
        Had this issue on an early version of this machine. Problem seems to be with the ribbon cable going to the CCD assembly. KM had made changes to the cable and cable holder to prevent issues like this. I can't bring up the bulletin about it at the moment, but that is likely the issue you have going on.
