New i-Series "Upward Compatible" Fusers (Fusing Unit II)
  • femaster
    • May 2011
    • 1508
    Konica has announced new fusers, yet again, for the i-series machines. Not sure how this affects other countries, but attached in the bulletin released for the US market.
    They are releasing what they are calling a "Fusing Unit II" which is "Upward Compatible" with both Versions (1 and 2) of their i-series of machines. This is not to be confused with the "Version 2" fusers that were released about a year ago. [Click here for V1 / V2 Details]
    This is something that should have been done in the first place, instead of having to fumble around with carrying 2 different fusers for the same machine model, depending upon the date of manufacture. What a shit show that is / was.
    13643 - Fusing Unit II for i-Series.pdf
  • SAR
    • Jul 2009
    • 203
    Re: New i-Series "Upward Compatible" Fusers (Fusing Unit II)
    Just got my first one of these fusers and it looks confusing initially, but I'm sure we'll all get used to it.
    I'll probably have to print off the bulletin and tape it to every one of these fuser boxes for a while, because I know I'll be getting calls from the other techs if I don't.
    • jotunn
      • 617
      So let's test this new fuser - load standard 80gsm paper into the tray, but set the paper as "thin" and print 10 pages of black gradation pattern from service mode. Check if toner is properly fused.
      • femaster
        • May 2011
        • 1508
        I just received 2 550i style and 1 450i style in place of a few Version 1 warranty replacements. We still have a couple of the original Version 1 fusers on hand, but with as fast as the V1's fail, it won't be long before we start installing these. I agree, it looks like quite the mess initially, at least until all the machines get converted over to handle the new fusers.
        Inside the fuser box is an instruction sheet along with a metal spacer plate and a longer screw. I didn't look too closely at it, but it looks like if you are installing the compatible fuser into a V1 machine for the first time, you have to install the additional metal spacer under the black plastic font fuser guide in the copier and replace one of the screws with the longer one to accommodate the extra height of the guide. Then you have to make sure the firmware is updated and an Engine switch is set properly depending on what model the machine is.
        • occus
          • 337
          KM makes it really complicated and confusing... First you have to ad the plate, after they modified the fuser and have to remove the plate with the new fusers... (only 450i/550i/650i)
          Now are Fusers Version 2 available..
          Fusing Belt breakage PSEU_BT2114174EN v2.0_.pdf
          "KMI has implemented the countermeasures into the following Fusing unit.Since the first countermeasure units, it’s no longer necessary to add the adjusting plate."
          • femaster
            • May 2011
            • 1508
            [ATTACH]61690[/ATTACH]
            That is very interesting. That is the first I've ever heard (or even read) of the fusing belt breaking issue. We have multiple hundred units out in the field and have never had that happen to a single machine. The issue we experience with the fusers is the surface of the belt wears through and you end up with toner sticking to the belt and then really dirty pages. I'm curious if the belt breaking problem is unique to the fusing units outside the US.
            • tsbservice
              Field tech
              • 8019
              Lately they said:
              - Fusing unit 2 needs always 2 plates
              - Fusing unit 1 needs always 1 plate except C750i/750i where there are 2 of them
              Funny how they hocus-pocus with us. I don't feel excited as I predict new improved fusers to be same sh*t.
              • occus
                • 337
                Yes... about the new fusers...
                I received yesterday a delivery of new c250i. These are already equipped with the new Fuser2. You can see on the backcover that the filter is sticking out and is no more plain.
                And of corse on the SNR of the Fusers AA2JA74Fxxxxxxxx upward.
                According to Technical Information
                BEU International Service
                Knowledge Article: RFEU_BT2317967EN: If you want install a Fuser2 on an Eagle1 you have to set engine dip sw 12 on / 40 off / 54 off.
                Kindly KM delivers the c250i with 12 on / 40 on / 54 off
                It's really tiring. Which configuration is the right one now? so that the Fuser lasts longer.
                ...not to mention that the first 3 devices I unpacked all made annoying noises from the power supply, but that's for another thread.
                • tsbservice
                  Field tech
                  • 8019
                  [ATTACH=CONFIG]61712[/ATTACH][ATTACH=CONFIG]61710[/ATTACH]
                  occus it's OK you marked wrong row it's ON for color machine C250i.
                  • occus
                    • 337
                    THX tsbservice, yes of course, sorry for my mistake. I was a bit busy.
