konica minolta 195 firmware
  • JINACHANDRANS
    • Sep 2019
    • 41
    Hi friends,
    Konica Minlota 195 shows "firmware update" message while switch ON the machine. How to solve it or help me to get the Konica Minolta Bizhub 195 firmware.
    Regards
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: konica minolta 195 firmware
    are you sure it was not in the process of a firmware update already?
    just asking because that message can popup after a reboot once the firmware is installed.
    • REGSIS
      • May 2016
      • 435
      Originally posted by JINACHANDRANS
      Hi friends,
      Regards
      If the machine was OFF for a long period of time this message is shown. In this case you have a chance for recovering.
      You must have installed twain driver for this model (you can prepare it with working machine) and connect to non working one. An unknown device will be shown in control panel since bizhub 195 can't boot. Show its properites and under driver (currently not installed) manually set twain driver of bizhub 195.
      After this step follow regular FW update from service manual.
      Good luck!
      • JINACHANDRANS
        • Sep 2019
        • 41
        Not try with any Firmware update. Previously Machine working good, all of sudden machine shows this error.
