C7000 wont boot
  • otphas
    • Aug 2019
    • 127
    C7000 wont boot
    Hi Guys,
    we have C7000 with strange problem. The machine wont boot, directly pop up error code C-C131, during the day had electricity problem and the machine switched off and on many times. When i saw the counter gone to 0 also all parts life are 0 and missing serial number. Also in service mode showing FACTORY MODE.
  • allan
    RTFM!!
    • 5462
    Re: C7000 wont boot
    What is the description of the error code?
    Whatever
    • tsbservice
      Field tech
      • 8052
      Re: C7000 wont boot
      Description C-C131 (CC131) error code after flashing firmware or replacing a board.
      Solution CAUSE: Firmware mismatch. SOLUTION: Check the firmware version I1 and C should have a firmware version that starts with the first 4 digits of the serial number.
      • otphas
        • Aug 2019
        • 127
        Re: C7000 wont boot
        Will check tomorrow ! Do you know what is mean FACTORY MODE message in service mode ?
        • otphas
          • Aug 2019
          • 127
          Re: C7000 wont boot
          We add manually the ser num and C-C131 gone, we installed firmware and seems all installed correct, but still counter is 0 and in service mode showing Factory mode.
          • wjurls
            • Feb 2017
            • 501
            Re: C7000 wont boot
            Sounds like your NVRAM may have taken a hit.
            • otphas
              • Aug 2019
              • 127
              Re: C7000 wont boot
              Is it have any procedure for recovery or initialization, seems problem is only software?
              • wjurls
                • Feb 2017
                • 501
                Re: C7000 wont boot
                The NVRAM holds all the critical and sensitive information of the machine it comes with. Meters and such. If they fail, you need Konica support to change it.
                Even then, it may never be the same again.
                I've never replaced one personally. If an old clunker like a C7000 has an NVRAM problem, I will take that opportunity to sell the customer a newer machine.
                Lee
