konica bizhub c454e serial number
  • Ametjari
    • Feb 2024
    • 2
    [Error Code] konica bizhub c454e serial number
    Hi everybody
    I have a problem in my printer konica bizhub c454e serial number must be entered contact your service representative
  • piksel1983
    • Oct 2018
    • 38
    Re: konica bizhub c454e serial number
    Check the battery
    Wysłane z mojego 22111317PG przy użyciu Tapatalka
    • Ametjari
      • Feb 2024
      • 2
      Originally posted by piksel1983
      Check the battery
      I already tried but doesn't work
      • copyman
        Owner / Technician
        • Sep 2005
        • 4785
        What do you mean you already tried? Did you test battery and see if 3V on MFP board in rear of machine? Many of the 4e series batteries are going bad. You lose serial number & counters
        • otphas
          • Aug 2019
          • 127
          Hi ,
          for sure your 3V battery is low voltage, serial you can add manually from service mode , System 1. You can serial number on the back side of the machine.
