How to discharge developer in C500?
  • ArtConnexion
    • Jul 2025
    I need to change Developer in a C500, I know hoy to charge it automatically, but not how to discharge it mannualy.
    Thanks for your help!
  • buster68
    • Nov 2008
    • 181
    Remove the developer from the copier. Remove your handy dandy developer tool from the inside of the copier(toner hopper area). Turn the unit upside down, so the hole where toner drops in is down, insert your handydandy developer tool in the coupling on the rear of the unit and turn til all the developer is dumped out of the unit.
    • JSC
      Gimp
      • Dec 2006
      • 618
      You MUST turn the mag roller in the correct direction or you WILL f**k up the seal/mylar in the dev unit and have to buy a new dev unit..
      The gene pool could use a little chlorine.
