Good day Bizhub 227
Printing is performed from the Linux environment without using a driver. There are 2 printable forms of the report.
Very simple 5 lines each The first is 1,2,3,4 (on four lines). (In HEX 0x31 0x0A 0x32 0x0A 0x33 0x0A 0x34 0x0A 0x0A)
The second, respectively, 5,6,7,8 (In HEX 0x35 0x0A 0x36 0x0A 0x37 0x0A 0x38 0x0A 0x0A)
When printing out, Konica Minolta Bizhub 227 prints them on separate 2 sheets, which is, in general, logical.
Can I the task is to print them on one sheet without paper feed (FF) after the first form with use PCLcode?.
On another device of another OKI brand - B6250, I can do this. Is it possible to do this on Konika Minolta using:?
1. Settings menu, (user or admin setting)
2. ESC sequences (PCL, PJL)
Attached 4 files
Thanks in advanc
Attached 4 files
Thanks in advanc
