Update on Scanner Drive Belt failure, C-360i series...
  • Oystercopy
    • Oct 2009
    • 623
    So, I had my first one of these throw a scanner code the other day. Had a heck of a time getting information on it from tech support, but basically, it turned out the scanner drive belt was bad.
    I brought one with me from another machine, but when I got out there, I was surprised what I found. Not only was the belt broken/shredded (machine only had 60K on it) but both the original belt and the new belt were both very STIFF.. this is unlike most cog style drive belts you'd had any experience with in the past.... I believe this rigidity and lack of pliability was what was causing these belts to break. Maybe they're getting them from a cheap supplier, but the part number hadn't changed (??)
    Additionally, I couldn't even get the new belt on without releasing some of the motor tension. I'm sure part of the reason for belt breakage also has to do with how tight the tension was adjusted from the factory. I know this is addressed in the bulletin on this issue that they sent me, but I would venture that I'm going to need to go into these things now and check every one of them for motor tension and release some of that. I don't know whose idea it was to tighten them that much, but it was a bad idea.
    Hope this helps someone!
    OC
  • avecosat
    • Jun 2012
    • 305
    Re: Update on Scanner Drive Belt failure, C-360i series...
    I have changed a few belts due to breakage or noise, I usually carry a couple of them in my suitcase.
    • Gift
      • Mar 2011
      • 2459
      Isn't the holder of the belt pressure roller "spring loaded". Usually you just need to loosen the screw and let that spring define the pressure and then tighten the screw angain.
      • tsbservice
        Field tech
        • 8016
        That's correct. I have changed so many of them and never came back.
        • kingarthur
          • 1356
          Yep - same part no - different quality. Don't you have to remove the motor to fit the belt, then tighten the screws once it's in place
          • tsbservice
            Field tech
            • 8016
            Yes motor to be removed then without connecting it should be spring loaded and 3 screw tighten in specific order.
            • tech51
              • 846
              I take that spring off and tension it manually. The strength of that spring is ridiculous. The belt only needs to move the mirrors, not the flipping Titanic😀.
              • Dickie
                • Nov 2011
                • 190
                There is a Tech Bulletin for this issue
                Find attached
                • PSKM_BT2012378EN.pdf (700.3 KB)
                • kingarthur
                  • 1356
                  Find attached
                  TBH, I'm not sure that'll make much difference - it's due to the quality of the belts - they're crap, as I said before, it's the same part no on the previous series, but the quality is completely different. We use the belts from the previous series, which have and are working fine
                  • kenpio
                    • Dec 2015
                    • 201
                    There is a Free of Charge that you can get these from KM. I the warranty part for the service.
                    Hope this helps
