Konica Minolta c454e error code P-5 P-28 P-21
  • WisamM
    • Feb 2023
    • 17
    [Error Code] Konica Minolta c454e error code P-5 P-28 P-21
    Hello experts
    The problem started when the client had a dark printout, so I started with the Gradation Adjust-stabilizer process but the machine showed the value 0 `Zero` for all values.
    so according to the Service manual, I restarted the machine and printed the demo page and the result was good. I tried to continue the Gradation Adjust - stabilizer process but every time I got Stabilizer NG.
    I changed the transfer belt and cleaned the 2 IDC sensors and I still got Stabilizer NG (can not continue the process to click print or copy).
    now I have three error codes:
    P-5 IDC Sensor (Front)
    P-28 IDC Sensor (Rear)
    P-21 Color Regist Test Pattern
    The machine is working properly but I need to fix those errors to continue the Gradation Adjust process.
    Any suggestions ???
    Thanks in advanced
  • Albonline
    • Sep 2008
    • 1132
    Re: Konica Minolta c454e error code P-5 P-28 P-21
    Originally posted by WisamM
    Hello experts
    Any suggestions ???
    Thanks in advanced
    what condition are the other consumables? Developers, drum units.
    • WisamM
      • Feb 2023
      • 17
      Very good. you can check the attached test page.
      • Albonline
        • Sep 2008
        • 1132
        did you try reset and stabilize? the machine will never be happy while failing stabilizer. what are the tcr numbers looking like?
        • Albonline
          • Sep 2008
          • 1132
          is the shutter over the sensors opening? how did you clean them.
