Konica C360i incorrect toner
  • Tommy D
    • Jun 2020
    • 9
    bizhub C360i giving intermittent incorrect toner message on K and Y. Firmware updated. After replugging a few times, the machine boots up. We are planning to try new toner cartridges. Has anyone run into this incorrect toner issue?
  • Max
    • Oct 2011
    • 560
    Re: Konica C360i incorrect toner
    I had this once. Had to replace CPU board in the end.
    • avecosat
      • Jun 2012
      • 305
      test with the toner bottle detection sensor it has three pins and sometimes they bend
      • aberock
        • May 2022
        • 124
        replace the 3 pin . some times it bend / not contact inside
        • Tommy D
          • Jun 2020
          • 9
          Replacing with new toner bottle seems to have fixed the problem. Thanks!
          • 4Toon
            • Mar 2023
            • 112
            If the chip on the bottle is not fully down this can cause a bad connections with the three prongs. Also on the yellow I have ran into the smart chip reader "3 prong" not getting fully seated onto the yellow toner chip. With some ingenuity you can get the smart chip reader to put more pressure on the chip only have seen both of these issues a couple times.
            Permanently banned from Konica SSD.
