C3320i paper empty detection
  • jwai
    • May 2018
    • 508
    Hello,
    One C3320i that will display " replenish paper " during copying/printing.
    I tried copy one page, this message will showed a few second on feeding from tray, if I printed a large amount it will pause several times.
    Checked paper empty sensor / actuator and cleaned it, still no luck.
    Any idea about this case? thank you.
  • D Colour
    • 213
    Re: C3320i paper empty detection
    Have you checked the paper empty sensor in the sensor check? Does it read as it should?
    Everything that has a beginning, has an end.....
    • jwai
      • May 2018
      • 508
      [ATTACH=CONFIG]61897[/ATTACH]
      On idle status, the paper present/empty detection is OK.
      When copying/printing process is being taken, sometimes display this message during paper feeding through paper tray.
