Werid image on C300
  • leo
    • Jun 2008
    • 64
    Werid image on C300
    Only copying in colormode, i get yellow or red stripe on half of paper
    see PDF
    any ideas!
  • mrwho
    Major Asshole!
    • 4299
    That's odd, never seen anything like that before.
    Only when copying, you say? Printing is OK?
    Since the image defect respects the paper margins, I'd guess it has something to do with the scanner part of the machine, so I'm supposing printing comes out OK.
    I'd begin to check out cables and connections, specially in the scanner area and the cable between the scanner and the main body.
    Good luck with that one!
    Mascan42
    Ibid
    • Albonline
      • Sep 2008
      • 1151
      if thatwas the internal test print. i would reseat the ribbon cable to the print head board (from the mfp board). ive seen outputs like this before, could be ipb or ram. if this is only happening on copys, could be cable connections.
      • leo
        • Jun 2008
        • 64
        only on copies in colormode
