konica minolta 458e error code 2557
  • giordaxx
    • Mar 2024
    • 6
    Hello everyone. I've been trying to resolve a problem on a Konica Minolta Bizhub 458e for days..
    I'll explain everything briefly: once the machine runs out of toner it has loaded, instead of reloading it automatically, it jams while it's working, because when the toner is rightly missing the machine stops giving me the error 2557. Normally all the machines, once the toner stored in the developer runs out, it automatically rotates the bottle of toner present, in turn refilling the developer. The toner bottle doesn't turn for me. The strange thing is that if I manually refill the toner in the developer (therefore doing a MANUAL ADD TONER from service mode), the bottle turns and refills. Then in the test mode phase I have all completely black copies printed continuously. So the machine doesn't refill the toner at all and in the end it stops giving the error 2557 signal. I did all the necessary tests, I even tried disconnecting all the connectors (even on the cards) spraying a bit of spray on the contacts thinking maybe that this was a problem. no way.
  • tsbservice
    Field tech
    • 8019
    Re: konica minolta 458e error code 2557
    You may want to check toner sub-hopper. Sounds like sensor there is at fault.
    • Albonline
      • Sep 2008
      • 1151
      The sub hopper has a photo sensor for full detection. The design of the sub hopper is just perfect to guide spilled toner into the ps.
      • JasonSBE
        • Apr 2014
        • 186
        This is the first thing I'd check. The sensor can get toner spilled on it really easily, depending on the environment.
        • giordaxx
          • Mar 2024
          • 6
          [ATTACH=CONFIG]62069[/ATTACH]
          Thank you very much! I am indebted to you
