bizhub 3510f
  • Vesigoth
    • Mar 2008
    • 133
    bizhub 3510f
    hey guys. what's a c-133A on a 3510f thanks
  • copytechman
    • Nov 2008
    • 947
    • time2fly
      • Jul 2008
      • 134
      (30) C133A: Main Unit G/A Communication Failure
      <Detection Timing>
      Action
      Trouble
      Code
      Description
      C133A
      • Communications with the gate array for expansion I/O (the IC mounted
      on the Master Board) fail.
      • The Light Emitting Diode on the PWB-A Board does not flash.
      Relevant Electrical Components
      Master Board (PWB-A)
      Step Operations
      Ref.
      Page
      WIRING DIAGRAM
      Control signal
      Location
      (Electrical
      Components)
      1 Turn the copier off, then on again. — — —
      2
      Check each control board and the
      Master Board for proper connection,
      and correct as necessary.
      3
      Replace the Master Board if necessary.
      • Vesigoth
        • Mar 2008
        • 133
        bh 3510f code c-133A
        thank you everyone
