Konica C224e - really strange sporadic stripe on one Site
  • Clanki
    • Mar 2024
    • 1
    SKM_C284e24032718070_0001-DF.jpgSKM_C284e24032718070_0004.jpgSKM_C284e24032718070_0003.jpgSKM_C284e24032718070_0002.jpgSKM_C284e24032718070_0003.jpg
    Hello,
    a really strange Issue appeared on our Konica Minolta C224e, see attachments. I have a stripe on the 11mm wide stripe on the operator side. It's sporadic, the servereness ranges from nothing to a darkgray stripe with stripes of C, M, Y in it.
    It seems to be the measure-strips, which the machine uses to calibrate itself? The problem is getting worse, sometime the color-registration is greatly of (probably because is can't calibrate itself?).
    Another side-effect, but not sure is it is connected with the main-problem: slight ghosting of larger areas and lines, see attached images.
    I have a second machine (KM C224) to swap parts for finding the cause, if needed.
    I already tried: swapping the ITB, swapping the 2nd transfer roller, image-stabilisation in the admin-settings.
    What could i try to solve this? Thanks for any help, i'm at the end of my knowledge
    Greetings,
    Clanki
  • copier tech
    • 8200
    Re: Konica C224e - really strange sporadic stripe on one Site
    Originally posted by Clanki
    [ATTACH=CONFIG]62178[/ATTACH][ATTACH=CONFIG]62179[/ATTACH][ATTACH=CONFIG]62180[/ATTACH][ATTACH=CONFIG]62181[/ATTACH][ATTACH=CONFIG]62180[/ATTACH]
    Hello,
    Greetings,
    Clanki
    Those lines are caused by the transfer unit cleaning blade not cleaning the belt fully after the device has run a calibration.
    You say you swapped this unit with another one but I assume with a used one? If so fit a new transfer belt unit.
    Also if you are not using genuine Konica Minolta toner this will cause the same issue.
    • Tech09
      • Apr 2020
      • 147
      You also have background. Replace the transfer belt with a new one.
