Bizhub 421 code c6001
  • francois
    service manager
    • 32
    Hi i have a problem with a b421 that gives a code c6001. I try to reset it bud it does not work.
  • mrwho
    Major Asshole!
    • 4299
    I think that's a CCD related error, although I'm not sure what could be causing it.
    Check connections, check if exposure lamp lights properly, check white patch in the optics area, check mirrors... and good luck.
    Mascan42
    Ibid
    • copytechman
      • Nov 2008
      • 966
      C-6001 CCD board (CCDB) connection
      abnormality.
      Scanner section
      stops
      immediately.
      CCD board (CCDB)
      Overall control board (OACB)
      Check your scanner cabling etc..
      Regards!
      A.
