C1060L drum replacement help
  • matsan_offset@yahoo.com
    • Sep 2016
    • 43
    Hello masters.
    I have a km c1060l machine. I replaced 4 drums in this machine. What calibration operations do I need to perform from the service menu after this change? Thanks.
  • Synthohol
    Certified Konica Expert
    • 5888
    Re: C1060L drum replacement help
    7. After replacing the drum unit, conduct the following items.• Cleaning the dust proof glass (Refer to F.5.2.1 Cleaning thedust proof glass)• For the drum unit/Y: Counter reset of the parts counter number21 and number 22.• For the drum unit/M: Counter reset of the parts counternumber 23 and number 24.• For the drum unit/C: Counter reset of the parts counter number25 and number 26.• For the drum unit/K: Counter reset of the parts counter number27 and number 28.• Gamma automatic adjustment (Refer to I.4.4.6 GammaAutomatic Adjustment (Drum Peculiarity Adjustment))• Color registration automatic adjustment (Refer to I.4.3.12 ColorRegistration Auto.Adj. (Printer Adjustment))• Manual adjustment of color registration (Refer to I.4.3.13 ColorRegist.Gap Measurement (Printer Adjustment))• Density Balance Adjustment
    • Maximum density initial adjustment (Recommended to beconducted) (Refer to "I.4.4.9 Maximum density initialadjustment (drum peculiarity adjustment)")
    also working on a 100k$ machine without a service manual is nuts man.
    do you need one?
      • Sep 2016
      • 43
      Originally posted by Synthohol
      F.5.2.1 Cleaning thedust proof glassI.4.4.6 GammaAutomatic Adjustment (Drum Peculiarity Adjustment)I.4.3.12 ColorRegistration Auto.Adj. (Printer Adjustment)I.4.3.13 ColorRegist.Gap Measurement (Printer Adjustment)I.4.4.9 Maximum density initialadjustment (drum peculiarity adjustment)")
      do you need one?
      Thanks. I will do what you say tomorrow.
        • Sep 2016
        • 43
        do you need one?
        thanks. I did what you said, okay.
        I also changed CMYK Developer.
        The print was fine but at full ground pressure of 255 it was Magenta. It looks wavy, why do you think it might be like that?
        The test I did in the photo is an A4 arrow sheet.
        Here are the steps I took to fix the problem.
        The drum replacement (C-M) problem is not resolved.
        corona replacement (C-M) problem is not solved.
        Transfer belt roller 2nd replacement (C-M) problem not solved.
        windows were cleaned
        Why do you think it might be?thanks. I did what you said, okay.
        • Synthohol
          • 5888
          Originally posted by matsan_offset@yahoo.com
          I also changed CMYK Developer. should just have done a full PM at this point?
          The print was fine but at full ground pressure of 255 it was Magenta. It looks wavy, why do you think it might be like that? did you perform ALL the adjustments for DV replacement?
          Why do you think it might be?thanks. I did what you said, you did what the manual said.
          [ATTACH=CONFIG]62322[/ATTACH]
          there are so many fine adjustments when working on a production machine.
          at least if you did a PM there is the step by step screens that guide you from one adjustment to the next.
          all these steps and procedures are listed in the service manual.
          do you need one?
          just to ask, have you stopped the image at different stages to see where the issue starts.
          anyway, if you want the service manual id rather just give it to you than see you torture yourself
          • tehrancopy.com
            Senior tech
            • May 2016
            • 6
            have you changed full genuine drum unit or compatible drums ?
            it looks like developing unit magnet fault . please check what is the life of its DV unit .
