C364e scan to SMB fail
  • jwai
    • May 2018
    • 517
    Hello,
    One customer that have 3 copiers ( C364e, C258, 225i ), all set scan to SMB to PC.
    I found only C364e fail with " server connection error ", I exchanged place with other 2 copiers the same result occurred.
    All machines have updated F/W, so what reason cause this?
    In addition, C364e has Soft SW for setting SMB version like C258? ( Soft SW 162 )
  • Synthohol
    Certified Konica Expert
    • 5892
    Re: C364e scan to SMB fail
    is the user name added to the share full access permissions of the shared folder?
    Software SW No.219 0x00: SMB1.0/2.0 are available. (default)
    Software SW No.219 0x04: Only SMB2.0 is available.
    change ntlm to smb 2 as well.
    you may need GDB firmware unless the later versions incorporated the fixes?
    • jwai
      • May 2018
      • 517
      Yes, all are full access permission, and check SW 219 is 00 NTLM is v1/v2.
      Other C258 and 225i scan successfully only this C364e fail, firmware is GDT-M1.
      • rrrohan
        • Sep 2011
        • 1977
        what network error code does it give
