DI5510 toner spill
  • exCSER
    • Mar 2009
    • 98
    DI5510 toner spill
    Hi guys,
    I've got a DI5510 that is dumping toner onto the transfer/seperation corona assy. It is coming out of the developer housing at both ends of the mag roller. I found info on another model that mentioned this type of problem caused by a broken mylar seal inside the housing. Is this the same kind of thing for the 5510? Any info would be greatly appreciated! Thanks!
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Quick answer is yes. This topic has been discussed at length. Same as di650, and will also work with 7272, and 7255. I could go on and on but you should just check out the 650 post.
    • exCSER
      • Mar 2009
      • 98
      Thanks for the responce FIXTHECOPIER, but I can't find the post you were referring to. Can you be more specific? Thanks in advance.
      • fixthecopier
        ALIEN OVERLORD
        • 4714
        http://www.copytechnet.com/forums/ko...-di-650-a.html
        Hope this helps
        • liuping
          support
          top
          • ni311
            • May 2008
            • 658
            Check this post, too.
            http://www.copytechnet.com/forums/ko...-solution.html
            Konica Minolta Error Codes - Explanations and Solutions
            • langelot
              • Nov 2008
              • 85
              Try this...
              This will alleviate the problem quite a bit - actually more usefull if you were overtoning all the way across the developer sleeve - but it definitely won't hurt. You may have to clean the drumcarriage maybe once or twice between PM cycles (250k).
              Change dip-switch 5-1 to a 1
              Change dip-switch 23-3 to a 1
              this will lighten you toner density threshold in the developer unit - maybe also make your laser output higher to attract more toner to the drum.
              If still having issues, also change 5-0 to a 1 and 23-2 also to 1 along with the other dipswitches mentioned above. This will bring it to the lightest toner density threshold - I would not reccomend this for a print shop type environment or where heavy graphics/halftones are required.
              Good luck.
              Langelot
