The scanner does not work after an internet outage
  • abbdullah
    • Apr 2024
    • 1
    [Misc] The scanner does not work after an internet outage
  • kingarthur
    • 1369
    Re: The scanner does not work after an internet outage
    How long is a piece of string?.... more info is needed, unfortunately, even though some of "us" are good....however, "we" aren't good at guessing.... are you scanning to email, SMB...when the scan fails what is the network error code. if scanning to email, are you using 365, Gmail....another server. are all the devices, the ones that work, scanning to the same address as the ones that don't work, if scanning to email, are they all using the same SMTP, are they all scanning the same way......
    • rrrohan
      • Sep 2011
      • 1977
      probably gateway or DNS settings have changed
