Color Consumable Reminder
  • copiertechFC030
    • Jun 2025
    First Post, I was wondering if anyone has tried setting the consumable reminder to off in System 2 on KM color copiers. It says it will disable the IU life, fuser and transfer belt message. Has anyone tried this instead of resetting the chips?
  • mascan42
    • Oct 2008
    • 481
    No, this will only disable the full-screen warning message. The units will still run out at the scheduled time.
    • kingarthur
      • 1330
      I think that if you turn off the reminder, you will get no warning that the toner is about to run out. the m/c will just stop dead
      • mo0651
        • 1054
        You must turn Iu life stop Off also. These things run 4 ever. We've had a black Iu saying the warning for over a year. If you see a quality problem run stabilization. Change them if it becomes to frequent.
        • Vesigoth
          • Mar 2008
          • 133
          color, consumable, reminder
          hey man. how you doing ? my name is Steve. Saw post. I tried to find how to turn IU life stop to OFF & couldn't. Where is it ? Is it in dip/soft switches or what ? help me out please. hubs c350, c351 & such
          • copiertechFC030
            Hey Steve, just access the tech rep mode, then press stop,0,clear. Then select IU life setting and set iu life stop to off. The exact terms may be a little off but I am doing this from memory. I hope this helps.
