C253 Image unit reset
  • random
    Is it possible to reset this unit once it has reached end of life? Without swapping chips.
  • random
    Anyone? Just that I noticed the chip on these units has about 18pins where the other units only have about 6.
    • pepper38_cnd
      Field Service Manager
      • Aug 2005
      • 1075
      To the best of my knowledge, the only reset method is with a replacement chip.
      Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
      Now into Ip TV KODI Boxes
      • ck1
        • 485
        now can buy the chip ???
        • Jumping Jack Flash
          • Jul 2009
          • 66
          ResetBox for IU chips Bizhub C200/203/253/353 all region
          • pepper38_cnd
            • Aug 2005
            • 1075
            Well I am intrigued ! Jumping Jack are you the creator of this box? Do you own one? Have you seen it work?
            "The unlock code is sent via e-mail" does this mean that after purchasing this, the owner still has to pay for every reset?
            The idea of plugging something into the toner slot and then being able to reprogram any Image Unit is interesting but to me sounds very strange.
            I am really interested in hearing feed back from others.
            • Bizhub
              • 147
              And so am I !! The crypto chip on the C253/353 has a combination (secret) on the chip that prevents any data accurately being read.
              Why is the toner socket being used for the reset as the socket has not got any relation to the imaging units except they both arrive back at the MFP board. If you are interigating the main board to reset the counters, I would personally be very nervous about doing it as the main board will ultimately cost more than a resetter. Does the resetter reset the TCR Article counter ? or does it only reset the counter for the I/U and please tell me how the connections for the toner supply system interact with the encrypted imaging unit chips.
              I am very suspicious about this one, REMEMBER EVERYONE TO RESET A CHIP you need to interface directly with the chip in question.
              Then you have to buy the device and buy the codes ! What happens when you run out of codes ( no machine will accept the same encryption code twice !)
              If you buy a resetter you should pay once and that's it.
                • Jul 2009
                • 66
                Welcome Everybody,
                I have noticed your surprise and interest over my project. On the other hand, I feel sorry due to some unkind comments on a forum, which make an existence and usage of Resetter doubtful.
                I understand that biggest problem is to reset any IU in a place where a lack of toner Y, C, M exists. I assure you it is doable.
                I am not going to confirm and deny that something is possible or not, but I fairly request you to think over your opinions, which a content is not professional, but limited to knowledge of 1-wire, microwire or RS232 and free programs like PonyProg.
                My goal was to create a cheap and simple device made of available elements. Reset Box consists of specyfically programmed micro-controller. Making that device lasts about 2 hours.
                To create Rest Box, the knowledge of Digital Circuit, a programming of micro- controllers and plenty of time spent on the project are necessary. A device was made at the beginning of 2009 and tested by my colleagues. An additional error recovery menu for TCR was attached in June, 2009. A usage of Reset Box demands an introduction of a correct 8 sign code.
                A code introduction is to be used once only and generated in a separate program for a particular device with no limit of use. I will not explain a code usage now. I have not offered a device sell, but I can kindly avail a device to test for those who are interested.
                • strider5555
                  • Jun 2008
                  • 96
                  I would definitely like to know more about this device! How many times have you sucessfully used this device to reset the image units? Will you be making it available for sale to the public at some point? How are you generating the code to input? Your video was quite impressive. I would like to know when more people have tried it, and the results.
                  • emujo
                    • Jun 2009
                    • 3009
                    OK devils advocate here...Other than the occasional problamatic I/U that needs early replacement, why all the interest in resetting these units? They have reached their life spans. You're gonna reset the chip, throw the unit back into the MFP and have CQ problems that wont go away until you ...wait for it... here it comes.... PUT IN A NEW I/U!!!. I wouldn't invest a dime in this and here's why.. Right now I have happy customers. PM's are short and sweet. I carry a few spare fuses for fuser and transfer assys in case I use one of these units for trouble shooting. And guess what...the new C652/552s have K I/U with replaceable drums. Writing is on the wall..manufactures know the replacable units are expensive, future models will have servicable I/U and we can go back to the old days of re-stringing coronas, replacing blades and taking up an hour of our time doing drum maintenance. You're a day late and a doller short for this tool. EMujo
                    • RichMac
                      • 6
                      emujo do you know true cost of i/u's
                      emujo, are you making any money replacing i/u's? Cost for each unit is over $400 for some units. $1200 per PM is going to eat into your profit.
                      We have used the ChipLife and other brand resetters with VERY GOOD RESULTS.
                      Does your company owner know what the cost of servicing and potential savings is.. WAIT FOR IT.. here it comes.. I BET NOT!
                      • emujo
                        • Jun 2009
                        • 3009
                        I work for the manufacturer, and the cost of these replacement units are well known. This cost is factored into the price of the MFP and the click charges. If you're underpricing either to get the deal, then I can understand why you result to this practice to save money. Are you cracking open the I/Us to replace parts, or just putting the unit back in the MFP in the reset condition? Where do you even find parts for the I/Us? You can already extend the life through service mode and by the time quality drifts off you should have made a fair profit. I stand by my comments..you owe it to your customers to keep the MFP in the best possible condition by servicing it correctly. If not, there is a good chance they will be one of my customers next time around.
                        • Mr Spock
                          Vulcan Inventor of Death
                          • Aug 2006
                          • 2064
                          Please say it ain't so. I was hoping that I would be getting away from rebuilding IU units. Especially on the Toshiba 2500c series....
                          • copytechman
                            • Nov 2008
                            • 969
                            Oh my oh my! I'd thought I'd left those memories behind me forever!!! Yaarrgh! Not the 2500C much less the 3100C series!!! Ack!!! NooOo!
                            Regards!
                            A!
                            • azzikker
                              Dude, I sure am glad you don't work for me. If we didn't refuse the units and reset chips there is no way you can make money on those machines at the manufacturers recommended CPC. We have no trouble getting 2 lives out of an image unit and for you to say they will fail when you have never done such a thing is a joke. My techs do their best to save money on contracts and with your attitude it sounds like you could care less. I would not employ a tech with that attitude. Guess what. Our customers love our techs as well and they save us as much money as possible.
