C-2840 on C6500
  • seniortech
    • Dec 2007
    • 180
    C-2840 on C6500
    I have a C6500 that I am due to look at next week that is coming up with a constant code C-2840 - Gamma correction abnormality (PCC Sensor correction failure during Maximum Control). Both Sensor Assy and PRCB have been replaced with no effect.
    Has anyone seen this code before, any ideas what may be causing this? Have never seen this code before.
    Many Thanks
  • Splitcane
    • Dec 2008
    • 9
    I have one too. We have tried replacing all boards, without any effect.
    We are still searching for a solution.
    /Splitcane
    • edmund
      • Jul 2009
      • 29
      Have a look at the transfer belt .We had cuople of cases were the belt was running scew on the unit
      • Splitcane
        • Dec 2008
        • 9
        We have tried to replace the entire transferbelt unit, color reg unit, all boards. now we have ordert the harness betveen printer control board and color reg unit.
        /Thomas
        • Cantechman
          • Nov 2008
          • 226
          have you tried this...
          C-2840 (C2840)at startup.
          Solution
          CAUSE: The PGC sensor is malfunctioning.
          SOLUTION: Recall Standard Data to Factory Init from the Process Adj screen in Service mode.
          • harry2007
            • 52
            c6500
            Pull out the transfer belt unit and remove it.On the machine in upper-left side,near tranfer belt -inserted- is situated a long sensor board assy. remove this board and clean all sersors.
            Also this code appear if you reseted drum or developer counter but you don't realy change it.
            And STOP to change the PWBs !
            http://copierservicereset.com
            • seniortech
              • Dec 2007
              • 180
              /Thomas
              I replaced this harness and it cured the fault, turned out to be bad contacts within the connector that the color reg unit plugs into.
              • jma676
                Expert Tech
                • Mar 2009
                • 324
                Try this adj. (Printer Gamma Sensor Adjustment) Set Default With Data Reset.
                • Splitcane
                  • Dec 2008
                  • 9
                  C-2840
                  Our machine had a low serialnumber. We replaced all 4 printerheads to the new type. Problem solved.
                  • JAkelar
                    • Mar 2018
                    • 18
                    Re: c6500
                    Harry, on our machine they switched out the PCRB and did a rest that reset all the counters.. but we didnt change them
                    How do we fix this is we have a reset drum and developer counter?
                    changing the drums and developer?
