BIZHUB C353
  • thuo
    • 155
    BIZHUB C353
    I have a bizhub c353.it was working fine as network printer till a colegue went to service the machine.i understand he removed the NVRAM then after that machine stopped displaying the network option on the display.when connected to the network machine does not print.its only printing on usb cable.the machine does not show the controller option display.10 or so after machine is switched on it displays arp.i have tried data reset.removing hard disk but not responding.
    which way forward
    thank in advance
  • 8050
    • 88
    Have you tried reflashing firmware?
    • copytechman
      • Nov 2008
      • 966
      Is the serial # and marketing area set correctly in service mode? Seen that cause weird issues, especially after playing with nvrams!
      Regards!
      A.
      • thuo
        • 155
        Bizhub c353
        I have confirmed the serial # and the country,but i have not tried reflashing the firmware.please send me the procedure
        • thuo
          • 155
          does this machine surely require firmware upgrade
          • Juggy
            Technical Support
            • Sep 2007
            • 101
            Hi, This might be silly but some guys ignore. In service Mode did you go and select the correct controller 0 in case of internal control.
