What could be causing this code on a C500? 32-01
C500 with a 32-01 code
wizpar
according to service manualspecified time.
When the fixing cooling fan /1
and /2 (M10, M36, M37) were
ON, abnormality detection signal
of either of them was continuously
detected for the
Printer control board (PRCB)Fixing cooling fan /3 (M36)
Fixing cooling fan /1 (M10)
Fixing cooling fan /2 (M37)
Is it a jam code or a service code?
If it is a jam code, check the 3 one-way gears in the fuser gear box.
If it is a service code, see above post, by wizpar.The family that prays together, stays together!
Smile God created you and He doesn't make mistakes!
Relax, God IS in control!
Be still and know that I am God
Ps 46:10Comment
dl4tech
Service code. Ordered the above motors, turned out to be a sometimes slow turning M36, the second motor behind the first one. IO check 42-03 would show the motor turning once in a while (thus the code). Replaced and tested with the finisher and the covers off for 45 minutes. So far so good.Comment
