B161F Black copies
  • Robotech
    • Jul 2025
    B161F Black copies
    Hi, I seem to be having a recuring problem on this range of m/c in that the exposure lamp will not come on when placing a document on the glass or through the document feeder, you then have to unplug the m/c from the wall socket to reset. Have first tried replacing power supply and then "pwb P" it will then work but the problem reoccurres, weeks some times months later.
  • Cantechman
    • Nov 2008
    • 228
    The ribbon cable that runs from the ccd unit to the pwb-b board can cause issues. I would replace that to see what happens.
    • deep
      • Jun 2008
      • 208
      Also check the lamp voltage regulator inside the scanner unit.
      Kenny
