di200f c0070
  • rockinjon
    • 11
    di200f c0070
    Just before putting in the new imaging unit a coworker took a vacume to our copier. To make sure all the bad toner was completely out of the machine. Now though I get a c0070 when the users try to print jobs larger than 13 pages its like the toner cant keep up. Any suggestions would be appreciated.
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Remove the toner bottle rotate motor and inspect the small white plastic pin that is on the shaft. If the bottle has been twisted the pin cracks and the metal shaft that is in it gets in a bind while trying to turn. While the bottle is out, manually rotate the rotating cup to make sure it is not in a bind. I had this as a call today. It is very common on the 200/251/351 series if the bottle has ever been twisted or "unscrewed".
    • rockinjon
      • 11
      I opened everything up didnt see any damage to the plastic sleeves around the toner bottle motor. what i did notice is without the bottle it seems to rotates ok, but with the bottle it gets stuck
      • time2fly
        • Jul 2008
        • 134
        Check the toner door sometimes the hinge pins get damaged or the hinge itself. Also make sure that the collar that rotates the toner bottle is not out of alignment, with these machines you can still install a toner bottle and it may rotate but then it will stop because the sensor is not seeing any toner and/or it just finally jams up.
        • rockinjon
          • 11
          its not the door hinge because I was testing with that whole panel off. However, I will double check that alignment. It seemed ok but at this point anythings worth a shot with management breathing down my neck.
          • time2fly
            • Jul 2008
            • 134
            If that doesn't work then replacing the toner rotation motor is the next step
            • brent
              • Nov 2008
              • 1212
              I have not worked on these in a while thank gosh. it seems to me that there was an updated bracket that those toner add gears fit into. even thought I think the gears may be sheared off a bit and you can't see them. the new bracket made it so the gears did not stress. or did not move. I don't have a part number but that is probably what is going on. also you mentioned that you vaccumed out the bad toner? do you have a correct bottle in place? and more details. are you sure the code was reset and then it is going right back into this same code? you also mentioned that the back covers were off while you were watching the machine. are all sensors jigged so you can see it trying to work? sorry so many questions but your description was a little vague in some areas.
              just trying to help you fix this problem
              brent
              • rockinjon
                • 11
                The bottle in there is a new bottle of oem toner. the back cover was off and I was printing. The machine will print up to 13 copies without an error anything more I get a c0070 error.
                • time2fly
                  • Jul 2008
                  • 134
                  C0070
                  Step Check Result Action
                  1 Main Hopper Toner Replenishing Motor operation
                  check:
                  • Remove the Lower Rear Cover.
                  • Unlock the Toner Bottle Lock Lever.
                  • Block the Toner Bottle Cover Sensor.
                  • Turn the Toner Bottle a half turn by hand.
                  The Toner Bottle turns when the Toner Bottle
                  Cover Sensor is unblocked under the above
                  conditions.
                  YES Check step 3.
                  2 Main Hopper Toner Replenishing Motor operation
                  check: the voltage across CN43-2 on the
                  side of Master Board and GND changes from
                  DC0 V to DC24 V when step 1 is performed.
                  YES Change Main Hopper
                  Toner Replenishing Motor.
                  NO Change Master Board.
                  3 Toner Bottle Home Position Sensor operation
                  check through I/O check
                  YES Change Master Board.
                  NO Change Toner Bottle
                  Home Position Sensor.
                  • time2fly
                    • Jul 2008
                    • 134
                    C0070 Main Hopper Toner
                    Replenishing Motor malfunction
                    • The Toner Bottle Home Position Sensor remains
                    blocked (L) for a continuous 2-sec. period or more
                    while the Main Hopper Toner Replenishing Motor
                    remains energized.
                    unblocked (H) for a continuous 6-sec. period or
                    more while the Main Hopper Toner Replenishing
                    Motor remains energized.
                    • rockinjon
                      • 11
                      Thank you I will check all of that and get back with you.
                      • fixthecopier
                        ALIEN OVERLORD
                        • 4714
                        I would take the bottle rotate unit apart. The part that grtips the nub on the bottle can get broke and jam it up. This could explain why it does not work with a bottle. Also if the small white pin at the end of the motor is cracked, it will turn without the bottle.
