Never had anything like it before. Do you have the chance of trying out that fuser on another machine - or a fuser from a working machine on that one - in order to find out if the problem is with the fuser or with the machine itself?
' "But the salesman said . . ." The salesman's an asshole!' Mascan42
'You will always find some Eskimo ready to instruct the Congolese on how to cope with heat waves.' Ibid
This is our only machine, so i cant try another fuser
I believe it's caused by a failure of the 3 identical gears in the fusing drive train. All three have a one-way bearing and one fails. Sounds wierd but I swear its one of those 3 gears. If you find they are the cause then order and replace all 3.
