Bizhub PRO C6500 horizontal lines in print / drodas78
  • Abi Melaibt
    • 11
    Hi. I have the horizontal lines that the red arrows show in the attachment. I changed the four drum units because I thought that it was the drum units but I didn't get any better result. What do you think that is causing this? The problem I have is that I need import any spare part to my country because there's no distributor to buy locally. So I need some advice because I need to buy it and then wait for a while to get it. I want to order the spare parts that I most probably need. Or maybe it can be some adjustment issue? I can give 19,000 dpi resolution of a section of the print if some one thinks it would help to determine possible causes. I sent the image in mid size because it won't upload in higher resolution.
    Thank you.
  • KyoceraChris
    • Jun 2009
    • 112
    have you tried cleaning the optical mirrors?
    you gunna eat yo corn bread?!?
    • mrwho
      Major Asshole!
      • 4299
      Sorry, I can't find the attachment. Where can I check it?
      Mascan42
      Ibid
      • drodas78
        • Jun 2008
        • 91
        Hi. Here's the attachment if you need a better quality file please let me know. I appreciate very much your help.
        • drodas78
          • Jun 2008
          • 91
          I haven't tried anything yet. Can you explain me more about the optical mirrors cleaning procedure? Did you saw the attachment? I'm only doing prints from computer, I don't photocopying
          • mrwho
            Major Asshole!
            • 4299
            That seems to me like you have the underside of of your magenta developing unit dirty. I usually instruct my customers to pull out the unit holding the developing units and belt (can't remember the name) and blow (with their mouths) under each of the developing units to clear the laser paths. You can also take out the developing units and clean them yourself.
            Mascan42
            Ibid
            • dogsbody
              • Jun 2007
              • 289
              When I see something like that I print test page 1 at 128 density for each colour. You will then probably find something obstructing the laser path for that colour (under the dev tank) as MRWHO said.
              Cheers.
              The force will be with you always.
              • Herrmann
                • Jan 2006
                • 792
                Maybe, this is helpful for you:
                If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                • drodas78
                  • Jun 2008
                  • 91
                  Can you please upload the image as a jpg zipped with better resolution? I'm gonna try this but I want to be sure of doing the things right.
                  Thank you.
                  • Herrmann
                    • Jan 2006
                    • 792
                    Check your inbox
                    • drodas78
                      • Jun 2008
                      • 91
                      Check your inbox
                      Tnx. I will give a try and let you know. Very useful info!
                      • StormyKnight
                        • Dec 2008
                        • 50
                        Yes from your samples it seems to be the toner has dropped into the laser path after collecting on top of the dev units.....quite common unfortunately....
                        Has anyone worked out a way to reduce the toner being sprayed up on the top of the dev tanks so much? It really is a huge amount of toner...
                        • mrwho
                          Major Asshole!
                          • 4299
                          The way I see it, that's something unavoidable, since the top of the developing units is part of the suction system. The only remedy I see is to clean the machine periodically.
                          Mascan42
                          Ibid
                          • StormyKnight
                            • Dec 2008
                            • 50
                            Yes thanks, I guess the key is to keep the filters clean to allow as much airflow as possible....do you guys reduce the number of filters in the big filter box? I think we take out at least 3....since those 3 never get toner in them even after a full PM cycle....but even with those missing, we still get the toner drop/laser blocked issue from time to time....
                            • mrwho
                              Major Asshole!
                              • 4299
                              Never tried it - and I don't service those machines anymore, at least for now - but I guess you could only get rid of one of the two white filters safely - since you need at least one for holding out the toner and the metal one for the ozone.
                              Whether that would solve anything or not, I can't imagine.
                              Mascan42
                              Ibid
