C5500 with error code C-3803
  • jmandassociates
    • Sep 2008
    • 186
    Need help with a C5500 with error code C-3803. The machine got some water dripped on it from above in the ceiling. What should I try first?
  • tech51
    • 846
    Write it off and get the customer to claim for it on their insurance
    • jmandassociates
      • Sep 2008
      • 186
      I need to fix it.
      • jmandassociates
        • Sep 2008
        • 186
        It was already written off we are trying to fix it now
        • Si@danwood
          • Mar 2008
          • 154
          sc38-03 is abnormally low fuser temp.You will need to check out the fuser unit,lamps ,thermistors etc to make sure they all ok.Reset the fuser error code in softswitches bit 3-1,=0 and see what happens.If the fuser checks out and the code returns then i guess you will have a ACDB or PRCB issue.I had one in similiar circumstances and was the ACDB...Si
          • jmandassociates
            • Sep 2008
            • 186
            How do I get into the softswitches when the machine starts up it goes right to the error code message. I can't get into the utility counter or anything. What's the sequance of buttons to get in and reset the error code from that screen.
            • Herrmann
              • Jan 2006
              • 792
              Press and hold the "utility/counter" button, then turn the maschine on, this will bring you directly into service mode
              If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
