failed to memory overwrite
  • moonwalker3778
    • Jun 2008
    • 87
    Dear all,
    I am facing this prob at the start up screen of bizhub 350.machine displays only "failed to overwrite memory".
    any solutions pls.........
    thanks & regards
    Sudhakar naidu
  • ni311
    • May 2008
    • 658
    Did you try to reset it? A memory clear or something?
    • jprecht
      • Dec 2008
      • 104
      mem overwrite
      Inside front door on right remove cover to axcess service pcb short two init pins cheat front door and power up while depressing service reset sw on same board hold for 10 sec or so should reboot screen will say "initialization complete" try this first
      good luck jprecht
      IT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
      THAN TO SPEAK AND REMOVE ALL DOUBT
      • moonwalker3778
        • Jun 2008
        • 87
        hi,
        sorry the message is " failed to overwrite all data".
        i ll tell the brief history.machine was sold by us warranty also over.customer tried to give amc to a third party for the goose.but nobody aware that service password was already set to this machine.finally third party failed customer came back to us with this prob.
        • moonwalker3778
          • Jun 2008
          • 87
          ya i solved the prob its a firmware issue.
          Thanks guys for ur support.
