I just replaced my balck drum, (it had gotten scratched by some built up dust) I removed teh transfer unit to do so, I restarted the machine and ran 24,00 black images with no problems, came in the next mornign and when I boot the machine I get this error code, service code c-2451
I removed the tranfer unit and checked all connections, and from other posts assume that it is a fuse, can you help me locate the fuse, and if it is not the correct code for the fuse can you direct to the probable cause?.
Thanks, Karl
Thanks, Karl
