Di 470 MINOLTA NEED HELP
  • JustManuals
    • Jan 2006
    • 9838
    #16
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
    • Hansoon
      • Sep 2007
      • 3400
      #17
      Wow, that cleaning blade for sure has patina......
      Hans
      • BlueBlazer
        • 25
        #18
        Do you do a recalibration after you clean it? I managed to keep a misbehaving one of these going for a few months between cleaning by cleaning every surface around the cleaning blade(I mean EVERYTHING cue tips and all.) and recalibrating the ADF sensor after i finished. If I didn't recalibrate it would just dump toner and next time I restarted the machine I would have to clean it again.
        • Hansoon
          • Sep 2007
          • 3400
          #19
          Just a far thought: Is the sensor for the rear machine cover in place (lower left corner at the rear)? If knocked out of place or otherwise not functional the machine will not calibrate properly.
          Anyway, it looks the machine could need starter (developer), cleaning blade, antispill mylar and perhaps a new drum.
          Hans
          • SPBE
            • Sep 2010
            • 70
            #20
            Definatly needs the antispill mylar. Also I would make sure the waste toner box isn't full.
            • eg101
              • Jan 2005
              • 131
              #21
              Toner falling on the AIDC and 'splashing' on the copies is either from overtoning and/or anti spill plate cracking.
              • Proton
                • Oct 2010
                • 10
                #22
                Re: Di 470 MINOLTA NEED HELP
                Hans
                What is 'patina' means?
                • Proton
                  • Oct 2010
                  • 10
                  #23
                  How do i 're-calibrate' it?
                  • Proton
                    • Oct 2010
                    • 10
                    #24
                    Hans
                    Thanx Bos Hans
                    I already add starter (developer) change the cleaning blade with the new one &
                    using a tape from video cassette betamax as a antispill mylar, but drum is still fine.
                    • Proton
                      • Oct 2010
                      • 10
                      #25
                      i'm sure Sir, the waste toner box is far from full.
                      • Proton
                        • Oct 2010
                        • 10
                        #26
                        Wow,,, $12.77
                        next time baby,,,,
