Di 470 MINOLTA NEED HELP
  • KHAN
    • Aug 2006
    • 261
    HELLO FRIENDS I WANT TO REPLACE THE DRUM,CLEANING BLADE,DEVELOPER ,UPPER ROLLER ,WEB etc,
    I HAVE THE S.M FOR THIS COPIER,BUT I NEVER REPLACE PARTS IN THIS COPIER, IS THERE ANY SUGGESTION FROM THE EXPRIENCE PERSONS, BEFORE I AM GETING START WORK ON THIS COPIER.
    THANKS I WILL WAIT FOR REPLY?
  • vypurr
    Just make sure to remove ATDC sensor when vacumning out dev unit.
    And reset proper counters in tech rep mode
    • wagon
      Village Idiot
      • Dec 2006
      • 654
      The Di470 are a great machine - clean, clean, clean and you could get 300k between service calls - wash the main charger and tr/sep with a good detergent and put them in the sun to dry - then rewire the tr/sep with the correct wire. Don't forget to empty the waste toner box. And clean all of the transport rollers including the duplexer. Clean and lube the one way gear on the side door at the fuser end (don't forget the ozone filter). Clean the optics and the adf paper path too. While you are changing the drum blade change the antispill also. Don't forget to check/clean/replace the pin on the end of the mag roller.
      I loved these machines (450, 550, 470, 552) and could get excellent CQ and copies between calls with a couple of hours of thorough cleaning. I don't think I forgot too much.
      Kendall.
      If you are hitting your head up against a wall it always feels better when you stop.
      • KHAN
        • Aug 2006
        • 261
        Di 470
        ok thanks friends i will check all these points.
        thanks
        • Scott_Lewis
          • Mar 2007
          • 519
          No love for the Di550
          Kendall.
          Wow, never thought I'd see anyone that 'loves' this model series. It is about a c- in my book. I can't get them to stop jamming at the fuser seps. Have one that I cannot get to stop dribbling toner (or was it developer) off of the mag roller.
          Scott
          • sagebrother
            don't forget to change the D's collars too...
            • wagon
              Village Idiot
              • Dec 2006
              • 654
              Ah, yes, the SOME 450/550's liked to drop their guts occassionaly, but apart from that, they were pretty good! (Although the fuser life in the 470 was crap due to insufficient oil - I had a mod for that - in fact, all that series 450/550/470/552 - 1 million copies EASILY out of the UFR, if you did my mod)
              Kendall.
              • Scott_Lewis
                • Mar 2007
                • 519
                Kendall.
                OK, I'll bite. I'm going to guess you soaked the web roller in olive oil overnight before installing it on the fuser.
                I've just started installing new f/w that doubles the speed of the web advance. I've complained to Minolta in the past about how the PM 3 counter doesn't advance properly which is also what drives the web advance logic. Hoping that will make a positive difference.
                Scott
                • wagon
                  Village Idiot
                  • Dec 2006
                  • 654
                  You are right, my mod runs the web motor more often! Please bear in mind the mod I built was 3 years or so ago, before any 'new' firmware. It is an electronic mod for a standard machine. You would end up getting around 120k out of a web, but the seps lasted longer, less jams and the ufr lasted a long, long time (actually, I think I got over a million out of one machine!). No olive oil used, just some good old fashioned electronics.
                  Kendall.
                  • Proton
                    • Oct 2010
                    • 10
                    AIDC censor
                    Sorry before,,, for my bad English.
                    Can anyone help me?
                    I got this problem, that the AIDC sensor always covered by toner
                    So, everyday in the morning,,, i clean it first before it can operate during the day.
                    How can i fix this? i mean, i don't want to clean it everyday (this is troublesome)
                    anyone please do help me, i'm beg you all ...
                    i can't stand this anymore.....
                    • wagon
                      Village Idiot
                      • Dec 2006
                      • 654
                      Sounds to me like the machine needs a new developer or maybe it's overtoning a lot. Is it leaving spots of toner on the copies? It's also possible the recovery blade is worn out.
                      • Proton
                        • Oct 2010
                        • 10
                        Thanx a lot for becoming the first to respon....
                        May i ask the meaning of 'new developer'? is that mean to?? what i'm clueless
                        'Overtoning' i do put toner more than ussual, ussually = 0.5 Kg & now i put 1.0 Kg ( i think this is still ok )
                        Yes! it leaving spots on the copies,,, so the result is awfully ugly
                        But, i can sure you the blade is in perfect condition, tommorow i will provide you with picture... (cleaning time in the morning )
                        please do help me...
                        • wagon
                          Village Idiot
                          • Dec 2006
                          • 654
                          Proton,
                          It seems to me the machine needs a bit of love. Get a service manual and start with that.
                          • JustManuals
                            • Jan 2006
                            • 9838
                            The original post was in 2007. He most likely resolved the problem by now.
                            • Proton
                              • Oct 2010
                              • 10
                              Problems with pics
                              Proton,
                              Here it goes Bro..
                              [BEFORE]
                              [AFTER]
                              Where can i get the Service Manual?
                              Please do help me Bro...
                              I don't wanna do the "morning cleaning" the rest of my life.
                              Besides, sucking this toner every morning is bad for my health.
