Bizhub C250 ADF not being recognised
  • Tactiveboy
    • Dec 2008
    • 16
    I have a C250 bizhub which won't recognise it has an adf fitted. When you check the firmware it shows no adf firmware installed. I have flashed the machine firmware and tried a different adf with no luck.
  • jprecht
    • Dec 2008
    • 104
    no adf
    Hi, was this bx wking b4? if it was wking with the orig adf and quit than you have a conn/bd issue. obviously there are sev ":test pts" you need 2 ck. more info and get out your meter!! when you changed tops was same adf? if so eliminated pt of trouble. suggest you wk bkward on this one.
    IT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
    THAN TO SPEAK AND REMOVE ALL DOUBT
    • albasoul06
      maybe there is a fuse on the power board ... you know, just for the adf board ? like the fuse for the fuser unit, power unit... same thing
      • jprecht
        • Dec 2008
        • 104
        adf ?
        we need more info on this one , but still suggest you wk it bkwards!!
        jp
        • Tactiveboy
          • Dec 2008
          • 16
          Thanks for the replies. feel a bit of a div fault was a cracked loom which had blown a fuse on the power board.
